T7314 datasheet — TRIANGULAR TYPE
T7314: характеристики и производитель
| Партномер | T7314 |
| Производитель | List of Unclassifed Manufacturers |
| Серия | T7314 |
| Файл | PDF, 424 Кб |
Вопрос по T7314
Нужен аналог, схема включения или совет по применению T7314? Задайте вопрос на форуме: войдите или зарегистрируйтесь, создайте тему в разделе «Компоненты» и укажите T7314 в заголовке.
Похожие компоненты: T7314
| 000-7315-37R | TRANSFOMRMER |
Wurth Elektronik GmbH & Co. KG, Germany. |
| 000-7315-37R-LF1 | TRANSFOMRMER |
| 0009073158 | 3.96mm (.156") KK^ IDT Double Cantilever Contact, 15 Circuits, Tin (Sn), Feed-To, 26 and 27 Stranded, Fused Stranded, and 24 Stranded, Green ID St |
| 0009073178 | 3.96mm (.156") KK^ IDT Double Cantilever Contact, 17 Circuits, Tin (Sn), Feed-To, 26 and 27 Stranded, Fused Stranded, and 24 Stranded, Green ID St |
| 0009073187 | 3.96mm (.156") KK^ IDT Double Cantilever Contact, 18 Circuits, Tin (Sn), Feed- Through, 26 and 27 Stranded, Fused Stranded, and 24 Stranded, Green |
| 0015473101 | 1.27mm (.050) Pitch MX-50 Slimline Ribbon Cable Connector, Feed-Through Version Preloaded Upper Housing, 10 Circuits |
| 0022173102 | 2.54mm (.100) Pitch KK^ PC Board Connector, Bottom Entry, 0.38lm (15l) Gold (Au) Selective, 10 Circuits |
| 0022173112 | 2.54mm (.100) Pitch KK^ PC Board Connector, Bottom Entry, 0.38lm (15l) Gold (Au) Selective, 11 Circuits |
| 0022173122 | 2.54mm (.100) Pitch KK^ PC Board Connector, Bottom Entry, 0.38lm (15l) Gold (Au) Selective, 12 Circuits |
| 0022173132 | 2.54mm (.100) Pitch KK^ PC Board Connector, Bottom Entry, 0.38lm (15l) Gold (Au) Selective, 13 Circuits |
