T7600 Datasheet
T7600 и другие
| 0010897600 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 60 Circuits, 0.76lm (30l") Gold (Au) Selective Plating |
| 0010897601 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 60 Circuits, Tin (Sn) Plating, 2.72mm (.107") PC Tail Length |
| 0010897602 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 60 Circuits, 0.38lm (15l") Gold (Au) Selective Plating |
| 0010897760 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 76 Circuits, 0.76lm (30l") Gold (Au) Selective Plating |
| 0014-60-7603 | ASSEMBLY, CONNECTOR BOX I.D. SINGLE ROW/ .100 GRID GROUPED HOUSING |
| 001460-7603 | ASSEMBLY, CONNECTOR BOX I.D. SINGLE ROW/ .100 GRID GROUPED HOUSING |
| 0014607603 | ASSEMBLY, CONNECTOR BOX I.D. SINGLE ROW/ .100 GRID GROUPED HOUSING |
| 0015477606 | 2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 6 Circuits, 0.38lm (15l) Gold (Au) Selective Plating |
| 0015477608 | 2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 8 Circuits, 0.38lm (15l) Gold (Au) Selective Plating |
| 0015477760 | 2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 60 Circuits, 0.76lm (30l) Gold (Au) Selective Plating |
