T7234 Datasheet
T7234 и другие
| 0002092111 | 2.36mm (.093") Diameter, Standard .093" Pin and Socket Crimp Terminal, Series 7239, Male, with Tin (Sn) Plated Brass Contact, High Current, 14-18 AWG, Reel Packaged |
| 0009507231 | 3.96mm (.156") Pitch KK^ Crimp Terminal Housing, 23 Circuits |
| 0014567230 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version C, Front Ribs, Wire Size 22, 3.81lm (150l") Tin/Lead (SnPb), 23 Circuits |
| 0014567231 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 22, 3.81lm (150l") Tin/Lead (SnPb), 23 Circuits |
| 0014567232 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version G, Positive Lock, Wire Size 22, 3.81lm (150l") Tin/Lead (SnPb) |
| 0014567234 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version A, Nonpolarized, Wire Size 22, 0.38lm (15l") Gold (Au) |
| 0014567235 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version C, Front Ribs, Wire Size 22, 0.38lm (15l") Gold (Au), 23 Circuits |
| 0014567236 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 22, 0.38lm (15l") Gold (Au), 23 Circuits |
| 0014567237 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version G, Positive Lock, Wire Size 22, 0.38lm (15l") Gold (Au) |
| 0014567239 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version A, Nonpolarized, Wire Size 22, 0.76lm (30l") Gold (Au) |
