T121009 Datasheet
T121009 и другие
| 0015912100 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 10 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 0026612100 | 3.96mm (.156") Pitch KK^ Solid Header, Vertical, without Peg, 10 Circuits, Gold (Au) Plating |
| 0039012100 | 4.20mm (.165") Pitch Mini-Fit Jr. Receptacle Housing, Dual Row, UL 94V-2, 10 Circuits |
| 006208000121001++ | 1.0mmPitch ZIF Vertical Through hole Single- sided contact Slide lock |
| 006208010121001++ | 1.0mmPitch ZIF Vertical Through hole Single- sided contact Slide lock |
| 006208100121001++ | 1.0mmPitch ZIF Vertical Through hole Single- sided contact Slide lock |
| 006208110121001++ | 1.0mmPitch ZIF Vertical Through hole Single- sided contact Slide lock |
| 006208511210000+ | 1.0mmPitch ZIF Vertical Through hole Single- sided contact Slide lock |
| 006208511210008+ | 1.0mmPitch ZIF Vertical Through hole Single- sided contact Slide lock |
| 006208511210009+ | 1.0mmPitch ZIF Vertical Through hole Single- sided contact Slide lock |
