T7779 Datasheet
T7779 и другие
| 0015477706 | 2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 6 Circuits, 0.76lm (30l) Gold (Au) Selective Plating |
| 0015477708 | 2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 8 Circuits, 0.76lm (30l) Gold (Au) Selective Plating |
| 0015477710 | 2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 10 Circuits, 0.76lm (30l) Gold (Au) Selective Plating, Tin (Sn) PC Tail Plating |
| 0015477712 | 2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 12 Circuits, 0.76lm (30l) Gold (Au) Selective Plating |
| 0015477714 | 2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 14 Circuits, 0.76lm (30l) Gold (Au) Selective Plating |
| 0015477716 | 2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 16 Circuits, 0.76lm (30l) Gold (Au) Selective Plating, Tin (Sn) PC Tail Plating |
| 0015477718 | 2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 18 Circuits, 0.76lm (30l) Gold (Au) Selective Plating |
| 0015477720 | 2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 20 Circuits, 0.76lm (30l) Gold (Au) Selective Plating |
| 0015477722 | 2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 22 Circuits, 0.76lm (30l) Gold (Au) Selective Plating |
| 0015477724 | 2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 24 Circuits, 0.76lm (30l) Gold (Au) Selective Plating |
