T6001113 Datasheet
T6001113 - Phase Control SCR (125-175 Amperes Avg 100-1600 Volts)
T6001113
Powerex Power Semiconductors (POWEREX)
T6001113 и другие
0014600111
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version A, Nonpolarized, Wire Size 24, 3.81lm (150l") Tin/Lead (SnPb)
0399600111
8.00mm (.315") Beau Eurostyle Fixed Mount PCB Terminal Block, High Voltage 11 Circuits
14-60-0111
39960-0111
6001-1101C
6001 Series Delay On Operate Digital Timing Module Fixed Timing, Solid State Output
Tyco Electronics
89160-0111HA
3M Pak 100 Preassembled Wiremount Socket
3M Electronics
CMDD6001_11
SURFACE MOUNT ULTRA LOW LEAKAGE SILICON SWITCHING DIODE
Central Semiconductor Corp
CMOD6001_11
HF9318-006-0-0-1-1-1
1/2 CRYSTAL CAN HERMETICALLY SEALED RF RELAY
Hongfa Technology
ROS-2600-1119+
Voltage Controlled Oscillator
Mini-Circuits
