T1122 Datasheet
T1122 - TRIANGULAR TYPE
T1122
TRIANGULAR TYPE
T1122 и другие
0001.2711.22
0001.2711.22
0001.2711.22
0002091122
2.36mm (.093") Diameter, Standard .093" Pin and Socket Crimp Terminal, Series 2273,Female, with Tin (Sn) Plated Contact, Low Engagement Force, 18-22 AWG, Reel
0002091123
2.36mm (.093") Diameter, Standard .093" Pin and Socket Crimp Terminal, Series 2273, Female, with Tin (Sn) Plated Contact, Low Engagement Force, 18-22 AWG, Bag
0003-09-1125
2.36mm (.093") Diameter Standard .093 Pin and Socket Plug Housing, 12 Circuits, 3 Rows
0003091121
2.36mm (.093") Diameter Standard .093 Pin and Socket Receptacle Housing, 12 Circuits, 3 Rows, Panel Mountable, without Passive Locking Ramps
0003091122
2.36mm (.093") Diameter Standard .093 Pin and Socket Receptacle Housing, 12 Circuits, 3 Rows, without Panel Mount Ears, without Passive Lock Ramp
0003091125
0003091125
