T7133 Datasheet
T7133 - TRIANGULAR TYPE
T7133
TRIANGULAR TYPE
T7133 и другие
0001.2713.11
0001.2713.11
0001.2713.11
0001.2713.22
0001.2713.22
0001.2713.22
0001.2713.xx
Surface Mount Fuse, 5 x 20 mm, Time-Lag T, H, 250 VAC, Au plating
0009507131
3.96mm (.156") Pitch KK^ Crimp Terminal Housing, 13 Circuits
0014567130
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version C, Front Ribs, Wire Size 22, 3.81lm (150l") Tin/Lead (SnPb)
0014567131
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 22, 3.81lm (150l") Tin/Lead (SnPb)
