T6001013 Datasheet
T6001013 и другие
| 0014600101 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version A, Nonpolarized, Wire Size 24, 3.81lm (150l") Tin/Lead (SnPb),10 Circuits |
| 008383016001010 | High Temperature Box Header |
| 008383026001010 | High Temperature Box Header |
| 009176001011006 | SSL - Discrete Wire IDC |
| 009176001011106 | SSL - Discrete Wire IDC |
| 0760010110 | 10.30mm (.405") EXTreme ZPower Connector, 10 Press-Fit Tails, Tin (Sn) Plating, for 3.18mm (.125") Thick PC Board |
| 14-60-0101 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version A, Nonpolarized, Wire Size 24, 3.81lm (150l") Tin/Lead (SnPb),10 Circuits |
| 76001-0106 | Mezzanine PCB Connectors |
MolexKits |
| 76001-0106 | Parallel Board Spacing |
| 76001-0110 | 10.30mm (.405") EXTreme ZPower Connector, 10 Press-Fit Tails, Tin (Sn) Plating, for 3.18mm (.125") Thick PC Board |
