T6410 Datasheet
T6410 и другие
| 0008-58-0641 | TERMINAL PIN 0.64 / .025 SQ. WIRE |
| 000858-0641 | TERMINAL PIN 0.64 / .025 SQ. WIRE |
| 0008580641 | TERMINAL PIN 0.64 / .025 SQ. WIRE |
| 0010897641 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 64 Circuits, Tin (Sn) Plating, 2.72mm (.107") PC Tail Length |
| 0014564100 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version C, Front Ribs, Wire Size 24, 0.76lm (30l") Gold (Au), 10 Circuits |
| 0014564101 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 24, 0.76lm (30l") Gold (Au), 10 Circuits |
| 0014564102 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version C, Front Ribs, Wire Size 26, 0.76lm (30l") Gold (Au), 10 Circuits |
| 0014564103 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 26, 0.76lm (30l") Gold (Au), 10 Circuits |
| 0014564104 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version C, Front Ribs, Wire Size 28, 0.76lm (30l") Gold (Au), 10 Circuits |
| 0014564105 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 28, 0.76lm (30l") Gold (Au), 10 Circuits |
