T9300 Datasheet
T9300 и другие
| 0009930300 | 3.96mm (.156") Pitch KK^ Crimp Terminal Housing, Friction Ramp, 3 Circuits, Glow Wire Compatible |
| 0009930400 | 3.96mm (.156") Pitch KK^ Crimp Terminal Housing, Friction Ramp, 4 Circuits, Glow Wire Compatible |
| 0009930500 | 3.96mm (.156") Pitch KK^ Crimp Terminal Housing, Friction Ramp, 5 Circuits, Glow Wire Compatible |
| 0009930600 | 3.96mm (.156") Pitch KK^ Crimp Terminal Housing, Friction Ramp, 6 Circuits, Glow Wire Compatible |
| 0009930700 | 3.96mm (.156") Pitch KK^ Crimp Terminal Housing, Friction Ramp, 7 Circuits, Glow Wire Compatible |
| 0009930800 | 3.96mm (.156") Pitch KK^ Crimp Terminal Housing, Friction Ramp, 8 Circuits, Glow Wire Compatible |
| 0009930900 | 3.96mm (.156") Pitch KK^ Crimp Terminal Housing, Friction Ramp, 9 Circuits, Glow Wire Compatible |
| 0039293026 | 4.20mm (.165") Pitch Mini-Fit Jr. Header, Dual Row, Vertical, without Snap-in Plastic Peg PCB Lock, 2 Circuits, PA Polyamide Nylon 6/6 94V-2, Tin (Sn) Plating, with Drain Holes |
| 0039293046 | 4.20mm (.165") Pitch Mini-Fit Jr. Header, Dual Row, Vertical, without Snap-in Plastic Peg PCB Lock |
| 0039293066 | 4.20mm (.165") Pitch Mini-Fit Jr. Header, Dual Row, Vertical, without Snap-in Plastic Peg PCB Lock |
