T4120 Datasheet
T4120 и другие
| 0009484128 | 3.96mm (.156") Pitch KK^ PC Board Connector, Top Entry, Polyester Connector, 5.0lm (200l") Tin (Sn), 12 Circuits |
| 0009484129 | 3.96mm (.156") Pitch KK^ PC Board Connector, Bottom Entry, Polyester Connector, 5.0lm (200l") Tin (Sn), 12 Circuits |
| 0009524124 | 3.96mm (.156") Pitch KK^ Crimp Housing, Female, Friction Ramp, 12 Circuits |
| 0010844120 | 6.35mm (.250) Pitch MLX Power Connector Header, Vertical, 12 Circuits, PA Polyamide Nylon 6/6 94V-2, Tin (Sn) Plating, White |
| 0010844122 | 6.35mm (.250) Pitch MLX Power Connector Receptacle, 2.13mm (.084") Contact Diameter, Vertical, PA Polyamide (Nylon) 6/6, Tin (Sn), White, 12 Circuits |
| 0010894122 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, High Profile, Dual Row, Right Angle,12 Circuits, 6.10mm (.240") Mating Pin Length, 0.38lm (15l") Gold (Au) Selective Plating |
| 0010894126 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, High Profile, Dual Row, Right Angle, 12 Circuits, 6.10mm (.240") Mating Pin Length |
| 0011-18-4120 | Conductor Punch |
| 001118-4120 | Conductor Punch |
| 0011184120 | Conductor Punch |
