T10120 Datasheet
T10120 и другие
| 0001.1012 | Miniature Fuse, 5 x 20 mm, Quick-Acting F, H, 250 VAC |
| 0001.1012.PT | Miniature Fuse with Pigtail, 5.4 x 22.5 mm, Time-Lag T, H, 250 VAC, UL: 115 - 300 VDC |
Cherry Semiconductor Corporation |
| 0001.1012.TR | Miniature Fuse with Pigtail, 5.4 x 22.5 mm, Time-Lag T, H, 250 VAC, UL: 115 - 300 VDC |
| 0015-91-0127 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 001591-0127 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 001591-0128 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 0015910120 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 12 Circuits, 0.38lm (15l) Gold (Au) Selective Plating |
| 0015910127 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 0015910127-ND | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 0015910128 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
