T1075 Datasheet
T1075 - T1/CEPT/ISDN-PRI TRANSFORMERS Dual Surface Mount, 1500 Vrms, Extended and Standard Temperature Range
T1075
T1075 и другие
0008560107
3.96mm (.156") Pitch KK^ Crimp Terminal 2578, 22-26 AWG, Reel, Brass, 0.51lm (20l") Selective Gold (Au)
0009061070
3.96mm (.156") KK^ IDT Trifurcon Contact, 7 Circuits, Tin (Sn), Feed-To, 20 Solid or Fused Stranded, and 18 Stranded, Red ID Strip
0009061079
3.96mm (.156") KK^ IDT Trifurcon Contact, 7 Circuits, Tin (Sn), Feed-Through, 20 Solid or Fused Stranded, and 18 Stranded, Red ID Strip
0009071078
3.96mm (.156") KK^ IDT Double Cantilever Contact, 7 Circuits, Tin (Sn), Feed-To, 20 Solid or Fused Stranded, and 18 Stranded, Red ID Strip
0009071079
0009071107
3.96mm (.156") KK^ IDT Double Cantilever Contact, 10 Circuits, Tin (Sn), Feed-Through, 20 Solid or Fused Stranded, and 18 Stranded, Red ID Strip
0009075107
3.96mm (.156") KK^ IDT Double Cantilever Contact, 10 Circuits, Tin (Sn), Feed- Through, 24 and 22 Solid or Fused Stranded, and 22 Stranded, Black I
0009481074
3.96mm (.156") Pitch KK^ PC Board Connector, Right Angle, Polyester Connector, 5.0lm (200l") Tin (Sn), 7 Circuits
0009501071
3.96mm (.156") Pitch SPOX Crimp Housing, Female, With Friction Ramp, 7 Circuits
0009521076
3.96mm (.156") Pitch KK^ PC Board Connector, Right Angle, Nylon Connector, 5.0lm (200l") Tin (Sn), 7 Circuits
