T1610 datasheet — 16 A Snubberless, logic level and standard Triacs
T1610: характеристики и производитель
| Партномер | T1610 |
| Производитель | STMicroelectronics |
| Серия | T1610 |
| Ток (из описания) | 16 А |
| Файл | PDF, 96 Кб |
Соседние компоненты серии T1610
| Компонент | Описание | Производитель |
| T1610-600G | 16 A Snubberless, logic level and standard Triacs |
| T1610-600G-TR | 16 A Snubberless, logic level and standard Triacs |
| T1610-800G | 16 A Snubberless, logic level and standard Triacs |
| T1610-800G-TR | 16 A Snubberless, logic level and standard Triacs |
| T1612MH | STANDARD TRIACS |
Вопрос по T1610
Нужен аналог, схема включения или совет по применению T1610? Задайте вопрос на форуме: войдите или зарегистрируйтесь, создайте тему в разделе «Компоненты» и укажите T1610 в заголовке.
Похожие компоненты: T1610
| 0001.2716.11 | Surface Mount Fuse |
| 0001.2716.11 | Miniature Fuse, 5 x 20 mm, Time-Lag T, H, 250 VAC, UL: 115 V - 300 VDC |
| 0009016101 | 3.96mm (.156") Pitch KK^ Crimp Housing, Edge Card Connector, Single-Sided, Surface Mount, Polarized, Without Flange, 10 Circuits, Rib between 4 & 5, 7 & 8 |
| 0009016121 | 3.96mm (.156") Pitch KK^ Crimp Housing, Edge Card Connector, Single-Sided,Surface Mount, Polarized, Without Flange, 12 Circuits, Rib between 5 & 6, 8 & 9 |
| 0009016151 | 3.96mm (.156") Pitch KK^ Crimp Housing, Edge Card Connector, Single-Sided, Surface Mount, Polarized, Without Flange, 15 Circuits |
| 0009016161 | 3.96mm (.156") Pitch KK^ Crimp Housing, Edge Card Connector, Single-Sided, Surface Mount, Polarized, Without Flange, 16 Circuits |
| 0009016171 | 3.96mm (.156") Pitch KK^ Crimp Housing, Edge Card Connector, Single-Sided,Surface Mount, Polarized, Without Flange, 17 Circuits, Rib between 5 & 6, 10 & 11, 14 & 15 |
| 0009016181 | 3.96mm (.156") Pitch KK^ Crimp Housing, Edge Card Connector, Single-Sided, Surface Mount, Polarized, Without Flange, 18 Circuits, Rib between 5 & 6, 10 & 11 |
| 0009016191 | 3.96mm (.156") Pitch KK^ Crimp Housing, Edge Card Connector |
