T73227 datasheet — 27 MHz VCXO Clock Generator IC
T73227: характеристики и производитель
| Партномер | T73227 |
| Производитель | List of Unclassifed Manufacturers |
| Серия | T73227 |
| Файл | PDF, 79 Кб |
Соседние компоненты серии T73227
| Компонент | Описание | Производитель |
| T7322 | TRIANGULAR TYPE |
| T73227-DIE | 27 MHz VCXO Clock Generator IC |
| T73227-M08 | 27 MHz VCXO Clock Generator IC |
| T73227-M08-TNR | 27 MHz VCXO Clock Generator IC |
| T73227-S08 | 27 MHz VCXO Clock Generator IC |
| T73227-S08-TNR | 27 MHz VCXO Clock Generator IC |
Вопрос по T73227
Нужен аналог, схема включения или совет по применению T73227? Задайте вопрос на форуме: войдите или зарегистрируйтесь, создайте тему в разделе «Компоненты» и укажите T73227 в заголовке.
Похожие компоненты: T73227
| 0010897322 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 32 Circuits, 0.38lm (15l") Gold (Au) Selective Plating, Tin (Sn) PC Tail Plating, 2.72mm (.107") PC Tail |
| 0022173222 | 2.54mm (.100) Pitch KK^ PC Board Connector, Bottom Entry, 0.38lm (15l) Gold (Au) Selective, 22 Circuits |
| 0034.7322 | Subminiature Fuse, 8.5 mm, Time-Lag T, 250 VAC, cULus |
| 010-89-7322 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 4 Circuits, Tin (Sn) Plating, 2.72mm (.107") PC Tail Length |
| 010-89-7322 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 32 Circuits, 0.38lm (15l") Gold (Au) Selective Plating, Tin (Sn) PC Tail Plating, 2.72mm (.107") PC Tail |
| 0173220000 | SAK-series |
Weidmuller |
| 0387007322 | 8.26mm (.325") Pitch Beau PCB Terminal Strip, with Mounting Ends, 22 Circuits |
| 0473220002 | 1.00mm (.039") Pitch ExpressCard* Header, Bottom Mount, Push-Push Type, Lead Free |
| 0473220003 | 1.00mm (.039") Pitch ExpressCard* Ejector, Bottom Mount, Push-Push Type, for34.00mm (1.34") Width Card, Lead Free |
| 0473220322 | 1.00mm (.039") Pitch ExpressCard* 34mm (1.34") Header, Bottom Mount, Push-Push Type, with 3.22mm (.127") Stand Off, Lead Free |
