T4122 Datasheet
T4122 - TRIANGULAR TYPE
T4122
TRIANGULAR TYPE
T4122 и другие
0009484128
3.96mm (.156") Pitch KK^ PC Board Connector, Top Entry, Polyester Connector, 5.0lm (200l") Tin (Sn), 12 Circuits
0009484129
3.96mm (.156") Pitch KK^ PC Board Connector, Bottom Entry, Polyester Connector, 5.0lm (200l") Tin (Sn), 12 Circuits
0009524124
3.96mm (.156") Pitch KK^ Crimp Housing, Female, Friction Ramp, 12 Circuits
0010844120
6.35mm (.250) Pitch MLX Power Connector Header, Vertical, 12 Circuits, PA Polyamide Nylon 6/6 94V-2, Tin (Sn) Plating, White
0010844122
6.35mm (.250) Pitch MLX Power Connector Receptacle, 2.13mm (.084") Contact Diameter, Vertical, PA Polyamide (Nylon) 6/6, Tin (Sn), White, 12 Circuits
0010894122
2.54mm (.100") Pitch C-Grid^ Breakaway Header, High Profile, Dual Row, Right Angle,12 Circuits, 6.10mm (.240") Mating Pin Length, 0.38lm (15l") Gold (Au) Selective Plating
0010894126
2.54mm (.100") Pitch C-Grid^ Breakaway Header, High Profile, Dual Row, Right Angle, 12 Circuits, 6.10mm (.240") Mating Pin Length
0011-18-4120
Conductor Punch
001118-4120
Conductor Punch
0011184120
Conductor Punch
