T2117 Datasheet
T2117 и другие
| 0001.2712.11 | Miniature Fuse, 5 x 20 mm, Time-Lag T, H, 250 VAC, UL: 115 V - 300 VDC |
| 0001.2712.11 | Surface Mount Fuse |
| 0002092111 | 2.36mm (.093") Diameter, Standard .093" Pin and Socket Crimp Terminal, Series 7239, Male, with Tin (Sn) Plated Brass Contact, High Current, 14-18 AWG, Reel Packaged |
| 0002092116 | 2.36mm (.093") Diameter, Standard .093" Pin and Socket Crimp Terminal |
| 0002092117 | 2.36mm (.093") Diameter, Standard .093" Pin and Socket Crimp Terminal |
| 0003121121 | 3.18mm (.125") Diameter, HCS-125 Pin and Socket Receptacle Housing, 12 Circuits, 3 Row, With Panel Mount Ears |
| 0005121102 | Crimp Terminal 6482, 14-18 AWG, Reel |
| 0006021103 | Flat Blade Appliance Motor Switch Crimp Housing, 10 Circuit, 10 Circuits |
| 0009016211 | 3.96mm (.156") Pitch KK^ Crimp Housing, Edge Card Connector, Single-Sided,Surface Mount, Polarized, Without Flange, 21 Circuits, Rib between 5 & 6, 10 & 11, 15 & 16 |
