T78041 Datasheet
T78041 - VERTICAL DEFLECTION OUTPUT CIRCUIT
T78041
Unisonic Technologies (UTC)
T78041 и другие
0359780410
3.96mm (.156") Pitch Wire-to-Board Header, Vertical, Low Profile, 4 Circuits
0359780420
3.96mm (.156") Pitch Wire-to-Board Header, Right Angle, Low Profile, 4 Circuits
0359780430
0359780440
3.96mm (.156") Pitch Wire-to-Board Header, Right Angle, Low Profile, 4 Circuits, Natural, Polyester Alloy
0737804143
2.00mm (.079") Pitch HDM^ Board-to-Board Daughtercard Receptacle, Vertical, SignalModule, 60 Circuits, Mounted Height 13.00mm (.511"), Pin Length 3.00mm (.118"),Press Fit
0780410002
6.35mm (.250") Pitch, EXTreme PowerPlus Header, All Power, Through Hole, Vertical, 3 Circuits, with Peg, Lead-free
0780451060
2.00mm (.079) Pitch, Milli-Grid Crimp Housing, 10 Circuits, with Center Polarization Key and side Locking Ramps, Leadfree
0780461020
2.00mm (.079") Pitch Milli-Grid Header, Right Angle, Through Hole, Shrouded, 10 Circuits
0885237804
SC/UPC-to-SC/UPC, Singlemode, 9/125lm/G652, Simplex, 2.00mm (.079), Standard Fiber Optic Cable Assembly, 10.0m (32.81)
0885277804
SC-to-ST, Multimode, 62.5/125lm, Duplex, 2.00mm (.079), Standard Fiber Optic Cable Assembly, 10.0m (32.81)
