T78040 Datasheet
T78040 и другие
| 0359780410 | 3.96mm (.156") Pitch Wire-to-Board Header, Vertical, Low Profile, 4 Circuits |
| 0359780420 | 3.96mm (.156") Pitch Wire-to-Board Header, Right Angle, Low Profile, 4 Circuits |
| 0359780430 | 3.96mm (.156") Pitch Wire-to-Board Header, Vertical, Low Profile, 4 Circuits |
| 0359780440 | 3.96mm (.156") Pitch Wire-to-Board Header, Right Angle, Low Profile, 4 Circuits, Natural, Polyester Alloy |
| 0737804143 | 2.00mm (.079") Pitch HDM^ Board-to-Board Daughtercard Receptacle, Vertical, SignalModule, 60 Circuits, Mounted Height 13.00mm (.511"), Pin Length 3.00mm (.118"),Press Fit |
| 0780410002 | 6.35mm (.250") Pitch, EXTreme PowerPlus Header, All Power, Through Hole, Vertical, 3 Circuits, with Peg, Lead-free |
| 0780451060 | 2.00mm (.079) Pitch, Milli-Grid Crimp Housing, 10 Circuits, with Center Polarization Key and side Locking Ramps, Leadfree |
| 0780461020 | 2.00mm (.079") Pitch Milli-Grid Header, Right Angle, Through Hole, Shrouded, 10 Circuits |
| 0885237804 | SC/UPC-to-SC/UPC, Singlemode, 9/125lm/G652, Simplex, 2.00mm (.079), Standard Fiber Optic Cable Assembly, 10.0m (32.81) |
| 0885277804 | SC-to-ST, Multimode, 62.5/125lm, Duplex, 2.00mm (.079), Standard Fiber Optic Cable Assembly, 10.0m (32.81) |
