T7026 Datasheet
T7026 - ISM 2.4 GHz Front End IC
T7026
ATMEL Corporation (ATMEL)
T7026 и другие
000-27025
MHV Connectors
Amphenol Corporation
0003067023
1.57mm (.062") Diameter Standard .062 Pin and Socket Plug Housing, Black, 2 Circuits, Without Mounting Ears, Black
0003097022
2.36mm (.093") Diameter Standard .093" Pin and Socket Plug Housing, 2 Circuits, Without Mounting Ears, Black
0003097024
2.36mm (.093") Diameter Standard .093" Pin and Socket Plug Housing, 2 Circuits, With Standard Mounting Ears
0009507021
3.96mm (.156") Pitch KK^ Crimp Terminal Housing, 2 Circuits
0010897702
2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 70 Circuits, 0.38lm (15l") Gold (Au) Selective Plating
0014567020
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version C, Front Ribs, Wire Size 22, 3.81lm (150l") Tin/Lead (SnPb), 2 Circuits
0014567021
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 22, 3.81lm (150l") Tin/Lead (SnPb)
0014567022
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version G, Positive Lock, Wire Size 22, 3.81lm (150l") Tin/Lead (SnPb)
0014567024
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version A, Nonpolarized, Wire Size 22, 0.38lm (15l") Gold (Au), 2 Circuits
