T5043 Datasheet
T5043 и другие
| 0001.2504 | Miniature Fuse, 5 x 20 mm, Time-Lag T, H, 250 VAC, UL: 115 V - 300 VDC |
| 0001.2504-ND | Miniature Fuse with Pigtail, 5.4 x 22.5 mm, Time-Lag T, H, 250 VAC, UL: 115 - 300 VDC |
Cherry Semiconductor Corporation |
| 0001.2504.PT | Miniature Fuse with Pigtail, 5.4 x 22.5 mm, Time-Lag T, H, 250 VAC, UL: 115 - 300 VDC |
| 0001.2504.TR | Miniature Fuse with Pigtail, 5.4 x 22.5 mm, Time-Lag T, H, 250 VAC, UL: 115 - 300 VDC |
| 0009065040 | 3.96mm (.156") KK^ IDT Trifurcon Contact, 4 Circuits, Tin (Sn), Feed-To, 24 and 22 Solid or Fused Stranded, and 22 Stranded, Black ID Strip |
| 0009065049 | 3.96mm (.156") KK^ IDT Trifurcon Contact, 4 Circuits, Tin (Sn), Feed-Through, 24 and 22 Solid or Fused Stranded, and 22 Stranded, Black ID Strip |
| 0009075047 | 3.96mm (.156") KK^ IDT Double Cantilever Contact, 4 Circuits, Tin (Sn), Feed- Through, 24 and 22 Solid or Fused Stranded, and 22 Stranded, Black ID |
| 0009075048 | 3.96mm (.156") KK^ IDT Double Cantilever Contact, 4 Circuits, Tin (Sn), Feed-To, 24 and 22 Solid or Fused Stranded, and 22 Stranded, Black ID Stri |
| 0009075049 | 3.96mm (.156") KK^ IDT Trifurcon Contact, 4 Circuits, Tin (Sn), Feed-Through, 24 and 22 Solid or Fused Stranded, and 22 Stranded, Black ID Strip |
| 0010085041 | 5.08mm (.200") Pitch KK^ Header, Vertical, with Polarizing Backwall, 4 Circuits, Tin (Sn) Plating |
