T10190 Datasheet
T10190 и другие
| 0010191081 | 5.08mm (.200") Pitch KK^ Header, Vertical, with Polarizing Backwall, 8 Circuits, Tin (Sn) Plating |
| 0010191091 | 5.08mm (.200") Pitch KK^ Header, Vertical, with Polarizing Backwall, 9 Circuits, Tin (Sn) Plating |
| 0010191121 | 5.08mm (.200") Pitch KK^ Header, Vertical, with Polarizing Backwall, 12 Circuits, Tin (Sn) Plating |
| 0010191141 | 5.08mm (.200") Pitch KK^ Header, Vertical, with Polarizing Backwall, 14 Circuits, Tin (Sn) Plating |
| 0010191161 | 5.08mm (.200") Pitch KK^ Header, Vertical, with Polarizing Backwall, 18 Circuits, Tin (Sn) Plating |
| 0010191181 | 5.08mm (.200") Pitch KK^ Header, Vertical, with Polarizing Backwall, 18 Circuits, Tin (Sn) Plating |
| 0019091019 | 2.36mm (.093) Diameter Standard .093" Pin and Socket Receptacle Housing With Positive Latch, UL 94V-2, 1 Circuit |
| 0032.1019 | FUSEHOLDERS / SICHERUNGSHALTER |
| 00620801019001++ | 1.0mmPitch ZIF Vertical Through hole Single- sided contact Slide lock |
| 00620801019020++ | 1.0mmPitch ZIF Vertical Through hole Single- sided contact Slide lock |
