T6001118 Datasheet
T6001118 и другие
| 0014600111 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version A, Nonpolarized, Wire Size 24, 3.81lm (150l") Tin/Lead (SnPb) |
| 0399600111 | 8.00mm (.315") Beau Eurostyle Fixed Mount PCB Terminal Block, High Voltage 11 Circuits |
| 14-60-0111 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version A, Nonpolarized, Wire Size 24, 3.81lm (150l") Tin/Lead (SnPb) |
| 39960-0111 | 8.00mm (.315") Beau Eurostyle Fixed Mount PCB Terminal Block, High Voltage 11 Circuits |
| 6001-1101C | 6001 Series Delay On Operate Digital Timing Module Fixed Timing, Solid State Output |
Tyco Electronics |
| 89160-0111HA | 3M Pak 100 Preassembled Wiremount Socket |
3M Electronics |
| CMDD6001_11 | SURFACE MOUNT ULTRA LOW LEAKAGE SILICON SWITCHING DIODE |
Central Semiconductor Corp |
| CMOD6001_11 | SURFACE MOUNT ULTRA LOW LEAKAGE SILICON SWITCHING DIODE |
| HF9318-006-0-0-1-1-1 | 1/2 CRYSTAL CAN HERMETICALLY SEALED RF RELAY |
Hongfa Technology |
| ROS-2600-1119+ | Voltage Controlled Oscillator |
Mini-Circuits |
