T3012 Datasheet
T3012 - TELECOMMUNICATIONS PRODUCTS
T3012
T3012 и другие
0005060301
Flat Blade Crimp Terminal, Series 2176, Female, With Tin (Sn) Plated Brass Contact, With Detent, 14-22 AWG (or 18 AWG Double Crimp), Reel Packaged
0008050301
KK^ Crimp Terminal, Series 4366, Female, with Selective Gold (Au) Plated Brass Contact, 18-24 AWG, Reel
0010883301
2.54mm (.100") Pitch C-Grid^ Breakaway Header, High Profile, Dual Row, Right Angle, 30 Circuits, 6.10mm (.240") Mating Pin Length, Tin (Sn) Plating
0010897301
2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 30 Circuits, Tin (Sn) Plating, 2.72mm (.107") PC Tail Length
0011-40-5301
Insulation Anvil
001140-5301
Insulation Anvil
0015045301
2.54mm (.100") SL Interim Clip, 30 Circuits
0015800301
2.54mm (.100) Pitch C-Grid^ Header, Through Hole without Peg, Dual Row, Vertical, Shrouded, High Temperature, 30 Circuits, Tin (Sn) Plating
0015911301
2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 30 Circuits, Tin (Sn) Plating, with 3.30mm (.130) PCB Locator Pegs
0022283301
2.54mm (.100) Pitch KK^ Header, Breakaway, Vertical, with Polarizing Wall, 30 Circuits, 0.38lm (15l) Gold (Au) Selective Plating
