T4773 Datasheet
T4773 - CMOS 256K-BIT EPROM
T4773
CMOS 256K-BIT EPROM
Toshiba Semiconductor (TOSHIBA)
T4773 и другие
0011-18-4779
Anvil
001118-4779
Anvil
0011184779
Anvil
0015477506
2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 6 Circuits, Tin (Sn) Plating
0015477508
2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 8 Circuits, Tin (Sn) Plating
0015477510
2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 10 Circuits, Tin (Sn) Plating
0015477512
2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 12 Circuits
0015477514
2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 14 Circuits, Tin (Sn) Plating
0015477516
2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 16 Circuits, Tin (Sn) Plating
0015477518
2.54mm (.100) Pitch C-Grid^ Header, Through Hole, Dual Row, Vertical, High Temperature, Shrouded, with Peg, 18 Circuits, Tin (Sn) Plating
