T4882 Datasheet
T4882 и другие
| 0015-91-0488 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 0015-91-1488 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 001591-0488 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 001591-1488 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 0015910488 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 0015910488-ND | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 0015911488 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 0015911488-ND | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 0072.4881.B1 | 120 - 360 VAC g 800 - 13000 A g 5 - 25 mm |
| 008560488 | KK.045 SQ PIN LOOSE |
