T0220 Datasheet
T0220 и другие
| 0001.1022 | Miniature Fuse, 6.3 x 32 mm, Quick-Acting F, Sand, 250 VAC |
| 0001.2022 | D-SICHERUNGSMATERIAL / MATERIEL DE COUPE-CIRCUIT D |
Cherry Semiconductor Corporation |
| 0001.2710.22 | Surface Mount Fuse |
| 0001.2710.22 | Miniature Fuse, 5 x 20 mm, Time-Lag T, H, 250 VAC, UL: 115 V - 300 VDC |
| 0003-09-2022 | 2.36mm (.093") Diameter Standard .093" Pin and Socket Plug Housing, 2 Circuits, With Standard Mounting Ears |
| 0003061022 | 1.57mm (.062") Diameter Standard .062 Pin and Socket Receptacle Housing, 2 Circuits, With Pre-bent Mounting Ears |
| 0003091022 | 2.36mm (.093") Diameter Standard .093" Pin and Socket Receptacle Housing, 2 Circuits, Without Mounting Ears, WIth Ramps |
| 0003092022 | 2.36mm (.093") Diameter Standard .093" Pin and Socket Plug Housing, 2 Circuits, With Standard Mounting Ears |
| 0003092022 | 2.36mm (.093") Diameter Standard .093" Pin and Socket Plug Housing, 2 Circuits, Without Mounting Ears |
