T6001613 Datasheet
T6001613 и другие
| 0014600161 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version A, Nonpolarized, Wire Size 24, 3.81lm (150l") Tin/Lead (SnPb) |
| 14-60-0161 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version A, Nonpolarized, Wire Size 24, 3.81lm (150l") Tin/Lead (SnPb) |
| 45560-0161 | Craddle Commector,SMT Right Angle Receptacle, Wire and PCB Termination Plug, IP-54 Rating |
MolexKits |
| 455600161 | 0.8MM HANDYLINK 16 CKT CRADLE CONN. ASSY PERPENDICULAR TO PCB |
| T6001613 | Phase Control SCR (125-175 Amperes Avg 100-1600 Volts) |
Powerex Power Semiconductors |
| T6001615 | Phase Control SCR (125-175 Amperes 1600 Volts) |
| T6001615 | Phase Control SCR (125-175 Amperes Avg 100-1600 Volts) |
| T6001618 | Phase Control SCR (125-175 Amperes 1600 Volts) |
| T6001618 | Phase Control SCR (125-175 Amperes Avg 100-1600 Volts) |
| T600161804BT | 1600V, 175A phase control single thyristor |
