T125 Datasheet
T125 и другие
| 026T120F102A1A | Industrial 15/16 inch (24mm) Diameter, 5-Watt, Wirewound Variable Resistors |
CTS Corporation |
| 026T120F102A1D | Industrial 15/16 inch (24mm) Diameter, 5-Watt, Wirewound Variable Resistors |
CTS Corporation |
| 026T120F102A2A | Industrial 15/16 inch (24mm) Diameter, 5-Watt, Wirewound Variable Resistors |
CTS Corporation |
| 026T120F102A2D | Industrial 15/16 inch (24mm) Diameter, 5-Watt, Wirewound Variable Resistors |
CTS Corporation |
| 026T120F102B1A | Industrial 15/16 inch (24mm) Diameter, 5-Watt, Wirewound Variable Resistors |
CTS Corporation |
| 026T120F102B1D | Industrial 15/16 inch (24mm) Diameter, 5-Watt, Wirewound Variable Resistors |
CTS Corporation |
| 026T120F102B2A | Industrial 15/16 inch (24mm) Diameter, 5-Watt, Wirewound Variable Resistors |
CTS Corporation |
| 026T120F102B2D | Industrial 15/16 inch (24mm) Diameter, 5-Watt, Wirewound Variable Resistors |
CTS Corporation |
| 026T120F102C1A | Industrial 15/16 inch (24mm) Diameter, 5-Watt, Wirewound Variable Resistors |
CTS Corporation |
| 026T120F102C1D | Industrial 15/16 inch (24mm) Diameter, 5-Watt, Wirewound Variable Resistors |
CTS Corporation |
