T7237 Datasheet
T7237 - Compliance with the New ETSI PSD Requirement
T7237
T7237 и другие
0002092111
2.36mm (.093") Diameter, Standard .093" Pin and Socket Crimp Terminal, Series 7239, Male, with Tin (Sn) Plated Brass Contact, High Current, 14-18 AWG, Reel Packaged
0009507231
3.96mm (.156") Pitch KK^ Crimp Terminal Housing, 23 Circuits
0014567230
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version C, Front Ribs, Wire Size 22, 3.81lm (150l") Tin/Lead (SnPb), 23 Circuits
0014567231
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 22, 3.81lm (150l") Tin/Lead (SnPb), 23 Circuits
0014567232
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version G, Positive Lock, Wire Size 22, 3.81lm (150l") Tin/Lead (SnPb)
0014567234
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version A, Nonpolarized, Wire Size 22, 0.38lm (15l") Gold (Au)
0014567235
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version C, Front Ribs, Wire Size 22, 0.38lm (15l") Gold (Au), 23 Circuits
0014567236
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 22, 0.38lm (15l") Gold (Au), 23 Circuits
0014567237
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version G, Positive Lock, Wire Size 22, 0.38lm (15l") Gold (Au)
0014567239
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version A, Nonpolarized, Wire Size 22, 0.76lm (30l") Gold (Au)
