T7300 Datasheet
T7300 и другие
| 0009073027 | 3.96mm (.156") KK^ IDT Double Cantilever Contact, 2 Circuits, Tin (Sn), Feed- Through, 26 and 27 Stranded, Fused Stranded, and 24 Stranded, Green I |
| 0009073057 | 3.96mm (.156") KK^ IDT Double Cantilever Contact, 5 Circuits, Tin (Sn), Feed- Through, 26 and 27 Stranded, Fused Stranded, and 24 Stranded, Green I |
| 0009073059 | 3.96mm (.156") KK^ IDT Trifurcon Contact, 5 Circuits, Tin (Sn), Feed-Through, 26 and 27 Stranded, Fused Stranded, and 24 Stranded, Green ID Strip |
| 0009073060 | 3.96mm (.156") KK^ IDT Trifurcon Contact, 6 Circuits, Tin (Sn), Feed-To, 26 and 27 Stranded, Fused Stranded, and 24 Stranded, Green ID Strip |
| 0009073088 | 3.96mm (.156") KK^ IDT Double Cantilever Contact, 8 Circuits, Tin (Sn), Feed-To, 26 and 27 Stranded, Fused Stranded, and 24 Stranded, Green ID Str |
| 0009073098 | 3.96mm (.156") KK^ IDT Double Cantilever Contact, 9 Circuits, Tin (Sn), Feed-To, 26 and 27 Stranded, Fused Stranded, and 24 Stranded, Green ID Str |
| 0010897300 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 30 Circuits, 0.76lm (30l") Gold (Au) Selective Plating |
| 0010897301 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 30 Circuits, Tin (Sn) Plating, 2.72mm (.107") PC Tail Length |
| 0010897302 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 30 Circuits, 0.38lm (15l") Gold (Au) Selective Plating, Tin (Sn) PC TailPlating, 2.72mm (.107") PC Tail |
| 0010897303 | 2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 30 Circuits, 0.76lm (30l") Gold (Au) Selective Plating, Tin (Sn) PC Tail Plating, 2.72mm (.107") PC Tail |
