T6401 Datasheet
T6401 - 30-A SILICON TRIACS
T6401
30-A SILICON TRIACS
T6401 и другие
0010897640
2.54mm (.100") Pitch C-Grid^ Breakaway Header, Dual Row, Vertical, High Temperature, 64 Circuits, 0.76lm (30l") Gold (Au) Selective Plating
0014564020
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version C, Front Ribs, Wire Size 24, 0.76lm (30l") Gold (Au), 2 Circuits
0014564021
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 24, 0.76lm (30l") Gold (Au), 2 Circuits
0014564022
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version C, Front Ribs, Wire Size 26, 0.76lm (30l") Gold (Au), 2 Circuits
0014564023
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 26, 0.76lm (30l") Gold (Au), 2 Circuits
0014564024
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version C, Front Ribs, Wire Size 28, 0.76lm (30l") Gold (Au), 2 Circuits
0014564025
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version D, Back Ribs, Wire Size 28, 0.76lm (30l") Gold (Au), 2 Circuits
0014564030
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version C, Front Ribs, Wire Size 24, 0.76lm (30l") Gold (Au), 3 Circuits
0014564031
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version D, Back Ribs, Wire Size 24, 0.76lm (30l") Gold (Au), 3 Circuits
0014564032
2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female, Single Row, Version C, Front Ribs, Wire Size 26, 0.76lm (30l") Gold (Au), 3 Circuits
