T15101 Datasheet
T15101 и другие
| 0015-91-5109 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 001591-5109 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 0015915109 | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 0015915109-ND | 2.54mm (.100) Pitch C-Grid^ Header, Surface Mount, Dual Row, Vertical, 4 Circuits, Tin (Sn) Plating, without PCB Locator Pegs |
| 0022415101 | 2.54mm (.100") KK IDT Double Cantilever Contact, 10 Circuits, Tin (Sn), Feed-Through, 26 Stranded |
| 0022415102 | 2.54mm (.100") KK^ IDT Double Cantilever Contact, 10 Circuits, Tin (Sn), FeedThrough, 24 Stranded, Solid, Fused, Topcoat |
| 0026615100 | 3.96mm (.156") Pitch KK^ Solid Header, Right Angle, with Friction Lock, 10 Circuits, Gold (Au) Plating |
| 0033.1510 | VOLTAGE SELECTOR SWITCHES / SPANNUNGSWAHLER |
| 0034.1510 | Miniature Fuse, 5 x 20 mm, Quick-Acting F, L, 250 VAC |
| 0034.1510.PT | Miniature Fuse, 5 x 20 mm, Quick-Acting F, L, 250 VAC |
