T1144 Datasheet
T1144 - T1/CEPT/ISDN-PRI TRANSFORMERS Dual Surface Mount, 1500 Vrms, Extended and Standard Temperature Range
T1144
T1144 и другие
0008500114
KK^ Crimp Terminal, 22-30 AWG, Bag, Hot Tin (Sn) Dip, Nickel (Ni) Under Plating
0008580114
CRIMP TERMINAL .156 CENTERS 18 TO 24 GA WIRE
0008650114
3.96mm (.156") Pitch KK^ Crimp Terminal 2478, 18-24 AWG, Reel, Phosphor Bronze, 0.38lm (15l") Selective Gold (Au)
0009061140
3.96mm (.156") KK^ IDT Trifurcon Contact, 14 Circuits, Tin (Sn), Feed-To, 20 Solid or Fused Stranded, and 18 Stranded, Red ID Strip
0009061149
3.96mm (.156") KK^ IDT Trifurcon Contact, 14 Circuits, Tin (Sn), Feed-Through, 20 Solid or Fused Stranded, and 18 Stranded, Red ID Strip
0009071140
0009071147
3.96mm (.156") KK^ IDT Double Cantilever Contact, 14 Circuits, Tin (Sn), Feed- Through, 20 Solid or Fused Stranded, and 18 Stranded, Red ID Strip
0009481114
3.96mm (.156") Pitch KK^ PC Board Connector, Right Angle, Polyester Connector, 5.0lm (200l") Tin (Sn), 11 Circuits
0009481144
3.96mm (.156") Pitch KK^ PC Board Connector, Right Angle, Polyester Connector, 5.0lm (200l") Tin (Sn), 14 Circuits
0009481145
KK 156 HOUSING PCB 41815 SERIES
