T6074 Datasheet
T6074 и другие
| 000-16075 | Adapters, Between Series Straight, Jack to Plug or Jack to Jack |
Amphenol Corporation |
| 0009016071 | 3.96mm (.156") Pitch KK^ Crimp Housing, Edge Card Connector, Single-Sided, Surface Mount, Polarized, Without Flange, 7 Circuits, Rib between 3 & 4 |
| 0009626074 | 3.96mm (.156") Pitch KK^ PC Board Connector, Bottom Entry, Nylon Connector,5.0lm (200l") Tin (Sn), 7 Circuits |
| 0009626075 | 3.96mm (.156") Pitch KK^ PC Board Connector, Top Entry, Nylon Connector, 5.0lm (200l") Tin (Sn), 7 Circuits |
| 0014-60-7023 | ASSEMBLY, CONNECTOR BOX I.D SINGLE ROW - .100 GRID GROUPED HOUSINGS |
| 0014441607 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Male, Single Row, Version D, Back Ribs, for Wire Size 26, 0.38lm (15l") Gold (Au), 7 Circuits |
| 0014450607 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Male, Single Row, Version D, Back Ribs, for Wire Size 26, 3.81lm (150l") Tin (Sn), 7 Circuits |
| 0014566079 | 2.54mm (.100") Pitch SL Insulation Displacement Connector Assembly, Female,Single Row, Version A, Nonpolarized, Wire Size 22, 3.81lm (150l") Tin/Lead (SnPb), 7 Circuits |
| 001460-7023 | ASSEMBLY, CONNECTOR BOX I.D SINGLE ROW - .100 GRID GROUPED HOUSINGS |
