T1125 Datasheet
T1125 и другие
| 0001.2711.22 | Miniature Fuse, 5 x 20 mm, Time-Lag T, H, 250 VAC, UL: 115 V - 300 VDC |
| 0001.2711.22 | Surface Mount Fuse |
| 0002091122 | 2.36mm (.093") Diameter, Standard .093" Pin and Socket Crimp Terminal, Series 2273,Female, with Tin (Sn) Plated Contact, Low Engagement Force, 18-22 AWG, Reel |
| 0002091123 | 2.36mm (.093") Diameter, Standard .093" Pin and Socket Crimp Terminal, Series 2273, Female, with Tin (Sn) Plated Contact, Low Engagement Force, 18-22 AWG, Bag |
| 0003-09-1125 | 2.36mm (.093") Diameter Standard .093 Pin and Socket Plug Housing, 12 Circuits, 3 Rows |
| 0003091121 | 2.36mm (.093") Diameter Standard .093 Pin and Socket Receptacle Housing, 12 Circuits, 3 Rows, Panel Mountable, without Passive Locking Ramps |
| 0003091122 | 2.36mm (.093") Diameter Standard .093 Pin and Socket Receptacle Housing, 12 Circuits, 3 Rows, without Panel Mount Ears, without Passive Lock Ramp |
| 0003091125 | 2.36mm (.093") Diameter Standard .093 Pin and Socket Receptacle Housing, 12 Circuits, 3 Rows |
| 0003091125 | 2.36mm (.093") Diameter Standard .093 Pin and Socket Plug Housing, 12 Circuits, 3 Rows |
